audio: Connect Audio equipment Digital: Home-cinema system (mini TOSLINK cable) Analogue: Hi-fi equipment or amplifier (3.5 mm cinch cable)
hdmi: connect TV set (HDMI cable)
ethernet: connect Internet-Box (Ethernet cable)
usb: USB port
wps: connect the Swisscom Box wirelessly to the Internet-Box or restart pairing with the remote control
IR: port for IR receiver
LED behaviour
LED lights up white: the TV-Box is switched on. LED lights up red: the TV-Box is on standby, or has no Internet connection LED does not light up: the TV-Box is switched of
Frequently asked questions
Which Internet router can I use with the TV-Box?
The TV-Boxes can be connected with all Swisscom routers. With one restriction: the Voice Assistant cannot be used with the Centro Business router.
Can I combine more than one TV-Box?
Yes, each household can use up to 5 TV-Boxes. You can use any TV-Boxes. However, please note the device restrictions.
The TV-Box belongs to you and you are under no obligation to return it to Swisscom. However, if you no longer need the TV-Box, Swisscom can refurbish it and give it to another customer as a replacement device.
