When the clock is activated it displays the time and date on the handset when it rests on the charger and not in use. If you do not wish to have this function, you can switch it off. Proceed as follows:
- Menu
- Settings
- Advanced settings
- Timer display > OK
- Select > Switch off
You have the option to set an alarm on your HD-Phone.
Change the settings as follows:
- Menu
- Settings
- Alarm clock
- Set alarm
- Save (the alarm clock symbol will be displayed in the top display line)
When the alarm rings you can stop it by pressing the off (left) button. Every time you press the snooze option (right button or any other button) the alarm will ring again in another five minutes. If the alarm is not switched off, it will stop automatically after 10 minutes.
