Verificare l’estensione della rete in fibra ottica
Check optical fibre expansion
We are continuously expanding the fibre-optic network and improving Internet speeds. Check what speed is available where you are.
Check now
If there is no information on optical fibre in the search results, then no expansion is currently planned near you. You’ll be able to see when optical fibre expansion is planned for your area in My Swisscom or on the network expansion map.
Requirements for optical fibre
The new optical fibre technology (Fibre to the Home FTTH) enables you to enjoy Internet speeds of up to 10 Gbit/s. Prerequisites are as follows:
  • Optical fibre must be available in your area.
  • You must have a blue Internet L or an inOne SME Business Internet L subscription.
  • You must use an Internet-Box 3 or Internet-Box 4.
  • The fibre-optic module is connected to the Internet-Box 3.
Optical fibre expansion schedule
We are not able to give you a specific date for when the optical fibre network will be completed in your area. Technical difficulties and objections from local authorities or property owners can lead to delays at any time. The completion date can only be estimated more accurately as construction progresses.
FAQs
No suitable answer found?
Help from the Swisscom Community
