Set up and use
WLAN-Box 2
App instructions
The My Swisscom App will guide you through a step-by-step setup process for your device.
Scan the QR code to get started.
QR-Code
App instructions
Get to know the device
Frequently asked questions
No suitable answer found?
Help from the Swisscom Community
