Enterprise Telephony
On this page:
Find out how to switch to the new Enterprise Telephony service, set it up and use it on your mobile phone or computer.
What is Enterprise Telephony?
With the Enterprise Telephony service, you can make calls via audio with your fixed network business number, even if you are out of the office. Incoming calls can reach you on your smartphone/tablet or computer/laptop via your fixed network number. The service can be used through smartphone apps and desktop clients.
Switch to Enterprise Telephony
The Enterprise Telephony service offers your business lots of features and an improved user experience. Different steps are required to switch from the Business Communication app or Business Telephony app to the new app, depending on the service.
​ macOS
Requires macOS 13 or higher
​ Windows
Requires Windows 11 or higher
​ iOS
Requires iOS 16 or higher
Android
Requires Android 11 or higher
Important documents and release notes
Using Enterprise Telephony
FAQs
No suitable answer found?
Help from the Swisscom Community
